jcb1977
- Elkhart Lake, WI
- SX
I'm going to be adding a chartplotter/fishfinder to my sx210. I was planning on installing a new circuit back to the battery for the fishfinder and was going to copy the materials/routing for the stock radio which I believe is 16 gauge wire with a 15-amp blade style ATC fuse (see photo).
When I put this information into the blue sea circuit wizard - Circuit Wizard - Blue Sea Systems using 1 amps for load current, ~30' conductor length, with 800CCA battery, it says the blade style ATC fuses should not be used because they do not meet the AIC given the battery size. my battery is stock and came with my 2019 boat.
Does this mean the fuses that came with the boat are insufficient? I'm not an electrician but I believe the AIC is in the event of a short circuit, a heavy spike from the battery could melt a fuse with insufficient AIC and not allow it to trip, potentially starting a fire. It seems like the ATC fuses in the boat offer 1,000A AIC but the circuit wizard indicates the minimum should be 1,500AIC given the 800CCA from the stock battery.
Anyone have any insight on this? I feel like I'm missing something, like maybe there is another breaker/fuse somewhere to handle this?
