Jfannin
- SX
Hello
Plan on knock off my list of needs fixing for boat. I’ve got a few thing that’s needs attention so one at a time I hope to mark each thing off as fixed.
ISSUE #1. OIL ISSUE. (Fixed)
ISSUE #2. Port side No wake mode.
ISSUE #3. Throttle and RPM Balance.
ISSUE #4 Port side No key warning tones
ISSUE#1
2nd year with this 2007 sx230 dual MR1 HO. All good last year other then both motors sound a little rough to me, sounds like bb’s bouncing around but read this motor always sound like crap. Port side has noticeable exhaust buildup on the back of the boat around the exhaust port, so port smoked some. The port side sounded worse in my opinion, more bb’s but not by much if any actually. All oil looked fine when I bought it and was fine all last year. Another thing is the port sides pisser is much weaker then the Starboard side. Pisser lines all cleaned. Nothing major found.
Boat was winterized last year by flushing / running boat camper Antifreeze through them via water pump and 5g bucket. 3 Gallons both Starboard and Port side.
New season. Did oil change at the house yesterday before first trip out. Boat fired right up, weak port pisser like before.
Oil change done by hooking up to hose adapter thing. TURNED HOSE ON AND THEN TURNED MOTOR ON (found later it’s not like a normal boat motor). RAN 5 min then motor off, then water off. After running I pumped oil out with extractor. Pulled 2 quarts from Starboard pulled like 6 quarts from port (was like wtf). Changed Filters oil looked fine. NO MILKSHAKE AT THIS POINT. Saved oil though, Will check it tonight…
Added 2.5 quarts both port and starboard side. Level showed good on both sides.
Fired motor up again to and ran for 5 min just like before (water, start, run 5min, motor off, water off.) Oil levels both sides good, and oil looked good.
Shortly after oil change yesterday we took the boat out. ? runs fine just like last year.
Checked oil again on the water before running and after running for 5 mins and showed good at just below the full mark, same as at the house looked fine. After that we enjoyed the boat all day( hours) probably ran an 1/8 tank of fuel.
Before we left I checked the oil levels again and the levels were the same, just under full on the stick when threaded in. At this point I noticed the PORT side looked a bit MILKY. Then explained to the wife what BOAT stands for
SO CRAP… I work all weekend so next week I plan on looking to find the issue. Wondering a few things of course that I’ve read on here about [HASH=412]#3,[/HASH] exhaust, or manifold.
my self wondering about the pisser issue causing it instead… hopefully a new head or motor isn’t in order but we’ll see.
ANYTHING STAND OUT TO YOU ALL? CECK LIST YOU WOULD USE?
ISSUE#1
