2kwik4u
- Buffalo, NY
Took a big leap last weekend and ripped out the existing ceiling over our deck. It was a flat, cheap vinyl ceiling that the builders put in 7yrs ago when the house was constructed. We had a ceiling fan, but the wind up here on the hill has long since destroyed it, and the vinyl planks had some damage from the ceiling fan blades impacting during wind events.
Here's a before picture:
Here's what it looks like now:
So I got the ceiling out, and the stringer boards removed and back to bare "truss" construction. What we've noticed in the few days it's been like this is that we really like how open it is out there. The space feels much larger in general. We have the overhead space to run the porch heater without melting the vinyl ceiling, and we've enjoyed a few nights out there already. SO.....We really want to figure out how to vault the ceiling out there. Overall goal is to vault the ceiling, and add dimmable can lights. No fan this time, but I will be adding an outlet for a TV. Likely on the pole opposite the stairs.
SO, it seems pretty easy to me in concept. Sister 2x6's to the existing slanted truss pieces to make rafters. Then temporarily support those rafters as I cut out the existing trusses. Once those are cut out I would add in a (2) 2x8 ridge beam, and tie everything together. The ridge beam would tie into the existing truss over the door, and carry down along the end of the roof near the stairs that is currently hipped. The fore/aft and cross beams around the ceiling are engineered lumber. I have zero concerns about the vertical reactions being carried, however the change from purely vertical forces of the roof truss to the combined vertical/horizontal forces of a rafter system gives me some pause.
Here's what the timber looks like. This was taken during construction 7yrs ago.
You can see the framing here before all the trim went on.
I keep going round and round on this. The easy answer is to just replace the flat ceiling be beadboard or some other tongue/groove system and move on. The wood ceiling would likely take the heat of the existing patio heater, or we could replace the patio heater with a shorter/smaller unit that isn't so close to the ceiling. Can lights and everything become really easy that way. I got that covered. Man, sure would be nice to make it a nice vaulted ceiling though. Our second consideration is creating a tray ceiling, but I'm not sure if the juice is worth the squeeze in that setup. I feel pretty strong on the "all or nothing" wagon here, but am open to suggestions.
Anyone done this sort of thing before? Any tips? Thoughts in general?
