Michael Guzzo
- Tampa Fl.
- Limited S
Took my boat in for routine maintenance and several issues were found. Below are the issues and estimates. Would like to get you guys’ perspective on if I am getting ripped off or not.
$650 for all the annual maintenance on both engines. I expected this. Price was $500 last year but inflation so fine.
The below are issues they found upon inspection
$450 to replace Coolant hose clamps. Apparently corroded
$350 to replace Exhaust hose clamps. Apparently corroded also
$450 to remove and refurbish impellers. Says they are all beat up. Most likely from sucking up shells and sand at sandbar.
I declined to replace clamps this time but said yes to impellers.
After they got the impellers back they said they could not get them back in due to swollen housings on both sides. The total cost to replace both housings was in the ballpark of $1,000. What’s most frustrating is that the boat was running fine when I took it in. If I would have declined getting the impellers refurbished would I have been ok?
Do you all feel that these are fair prices for the work being done. Any other thoughts are appreciated.
Thank You!
Thank You!
