- Florida
- Other
- Other
I am on my 4th N A N O hull and so far every single one has developed leaks in the front possibly from beaching , although I have 2 nice anchors and I usually anchor my skies away from the shore I do bring them up close to the beach when add fuel.
I never let my tanks get to 1/2 since I just may want to go for a very long ride on a whim and I hate worrying about fuel. So I add fuel several times a day.
Last week I was riding my white 2014 FX HO cruiser with 300 hours on it.
I alternate them to keep the hours as close to even as possible. I was 5 miles from my launching point and I felt like I had weeds in the pump so I did my reverse move but nothing came out from under the ski like it usually does.
So I found a sand bar and felt up under the intake grate but nothing was stuck in there.
I decided to go slow since the hood was vibrating pretty badly at speed.
Then I noticed the water coming up over the hood and it dawned on me that I was taking on water. I know DOOH!
On these skies if the water gets high enough it gets into the dampener behind the engine and causes all sorts of vibration. I looked inside the ski and confirmed my suspicion.
I now had 5 miles to get back to my trailer, so I drove it back , in hind sight I should have pulled the 2 drain plugs and kept the ski going fast, this would allow the water to escape , I just did not think of that at the time, fortunately I managed to get back with no water ingestion, but it sure drained for a long time when I put it on the trailer.
I noticed the front of the hull had worn through in the curve of the bow " the usual place" .
So a word to the wise keep an eye on this and remember the ski will not sink even if you put it in the water all day with the plugs out so if you are taking on water you can pull the drain plugs and go fast to keep the volume of water low in the hull, mine was about half way up the engine but it never missed a lick. Also keep in mind that if you feel the hood vibrating violently at speed check for water in the hull "lots of it!"
I did thoroughly rinse everything and re apply white lithium grease to the engine and clamps and repaired the hull as I always do and I beef it up for better results.
