- Raleigh, NC 27614
- 242X E-Series
When I was looking at moving from an LX210 to a 230, I was more concerned about the ramifications of a plug blowout since the boat was more expensive! I looked at all the ways to prevent a blow out and wasn't convinced any of them were fool proof, so I decided that my best option was to at least know if a plug had blown and was forcing water into the bilge by installing a bilge alarm. Also, it would be an added peace of mind in a wet slip....at least I'd know she'd scream for help before she sank! LOL
Here is a link to what I bought (not saying this is the cheapest place to buy it from):
http://www.wholesalemarine.com/hi-water-bilge-alarm-system-12-volt.html?gclid=CNudvs7Cir0CFYdFMgodvjIA2Q
Rule 33ALA Marine High Water Bilge Alarm (Mercury Free, 12-Volt)
The install is pretty easy.....but does require you to drill holes in your boat!
I mounted the alarm right next to the current bilge pump and ran wires to the battery.
Then I drilled a hole for the alarm right in front of the binnacles as the fume detector already took the available space on my dash. You can see the black disk in front of the binnacle and behind the safety cable.
Edited to add product info
