  • Guest, we are pleased to announce that Lectrotab (Linear Devices Corp.) has generously offered discounts on their most popular Trim Tab kits to members of this Forum via a group by that runs through Tuesday, March 31, 2020. ACT FAST...TIME IS RUNNING OUT!!! Lectrotab is offering 55% off on the list price of any Lectrotab Trim tab configuration you can dream up!
    Click Here for more information>Lectrotab group buy for JetBoaters.net members only
Bilge pump issue
Ando
Los Angeles
My bilge pump doesn't turn ON.
Does it look like a fuse issue or a pump issue?
I plugged the drain plug. Filled the bilge with water and the pump wouldn't turn on.
It looks like upgraded pump like this one.
How do you guys reach the pump? I have to lay down on top of the engine and I can barely reach it. Stock on what to do with troubleshooting and replacing if needed.
Release the clips on the side and make sure the screen is clear and the impeller isnt jammed. Try spinning it by hand.
Ando
Los Angeles
The pump is just seating in the round hole?
I just pull it out? I can barely reach the top of it.
See the blue clips on the sides? Press those while lifting the pump up. The blue part will remain on the bottom of the bilge.
Ando
Los Angeles
The problem is reaching it. I can't even imagine how it was installed. I can reach one clip, but seems like another on the other side which is further away from m
Ando
Los Angeles
Am I supposed to be able to turn the impeller with fingers? Seems to be jammed20191101_011105.jpg20191101_011136.jpg
Ando
Los Angeles
I can disasable it?
Also the wiring seems to be going into the clean out plug side. There is nothing to unplug in the engine compartment.
Is that how they usually are? Meaning I need to remove the clean out plug tray to unplug the connectors if I want to replace it? Or do I just cut the wires and spice it together when new replacing the pump with a new one.
Jgorm
San Diego / Colorado river
Buy a new one for 50 bucks. Not even worth trying to fix. The stator is probably frozen in corroded windings. That's how 3 of mine died.
Betik
Frisco, TX
what @Jgorm said. Get a new one and peace of mind. They are too cheap to fix and worry that it might stuck again
Ando
Los Angeles
That's what I'm going to do I guess. What happened is I filled up with water and the pump turns on for like 3 seconds and you see water coming out from the discharge and then the light goes off on the switch and pump turns off. I took the pump out and it was working fine outside
