    With a Maximum discount of 35% this is the sale to get in on!
Bimini strap hook warning.
SCSX190
Lake Wylie, SC
Boat is 1 month old and the Bimini strap hook came undone while attempting to unhook it. I replaced with hardware from Lowe's on both sides to make it more secure. If the Bimini strap hook fails while at full throttle this could take someone's eye out.
sx998
Jacksonville, Fl
Mine did the same thing. Replaced with SS dog leash clips.
Wow...thats not good. The clip on my 2005 were fine... I had to replace the straps once and reused the OEM clips!
njmr2fan
Augusta GA
No doubt that one saved them $0.03 cents each from the beefier one they could have chosen.
Murf'n'surf
Naples Florida
Wow! 2 quickly confirmed failures.... This sounds like something Yanaha needs to look into.
Maybe they changed vendors for that part?
Big Shasta
Panama City Beach, FL
That's scary. I used to keep mine really tight on my 05AR230. Never had an issue though thankfully.
WildBillF1
Bullhead City, AZ
SX192
The OEM clips are junk. The third time my boat was on the water the starboard side clip looked just like yours, and the very next day the port side clip did too. Here's one of the new 1/4" clips.
Jetswu87
Mine just did this, this weekend...15 sx192. I just replaced them with some beefier versions..I'd love to see what others have used, I had to loop the strap around my clips.
SCSX190
Lake Wylie, SC
I went with a 2 piece setup so the strap and clip connect to the same piece.
Joe Hellaby
Scottsville, NY
Nice, yeah mine are just a few months old and are nearly still together. I've been really nervous the last couple outings and have been meaning to replace
Jetswu87
SCSX190..
I got the same clips, but I didn't do that ring. I looped the strap through the bottom and over the hood for a cinch.
MikeStat
Has anyone or know of anyone that just replaced the straps with poles?
zipper
Milton, Vermont Lake Champlain
Not heard of it. The straps allow you to adjust the tension on the bimini top, keeping it tight. Poles/rods are fixed and do not allow to tighten as materials change or stretch over time. There are poles on the aft side of my bimini. The straps forward, tighten it.
