scubasteve87
- Long Island, NY
- SX
Hey Everyone! Been on the site for a bit now and I'm looking to pick the brains of some other users as I begin to track down an issue that has crept up the past few weeks.
Quick background:
-Boat currently has about 60 hours, 2nd season, completely stock other than a seadek install. Went through 10 hour service last year at the dealer, I winterized the boat and I changed plugs and oil at the start of the season myself (April). Boat has run flawlessly for the first 15 or so hours this season.
-About 3 weeks ago had a rough 2 hour ride back in 3-5 footers after a nice weekend trip. The SX195 handled it much better than expected, albeit averaging only 15-19 MPH for most the trip plowing into some waves. (I boat in bays/coastal waters, Long Island, NY)
-The Following weekend/outing, noticed some immediate cavitation off launch and topping out at 6800 RPMs with top speed only around 35. Pulled over, pulled some seaweed out of the clean-out port and continued on with no issues. Thought it was that simple, but I've noticed I had generally good launches like normal, but could only manage to top out at 45mph around 7100 RPMs.
-Normally with the weight configuration and weather I had that day I can usually touch 50mph comfortably with RPMs around 7500.
-Didn't think too much of it at the time when I first had the issue, but the boat has sounded and felt a little "off" the last few times I have taken it out. By off I mean more cavitation than normal (more so at higher RPM and speed), engine running a little louder than normal (more noise and increase in vibration throughout the boat) and general lack of performance
-Boat still launches well and has the power from the start for the most part and haven't really lost anything on the get up and go. But pushing over 6500 RPMs is where I start noticing the loss of general power compared to last year and earlier this year
-engine feels and sounds a little louder, little "heavier" like it is fighting something that's holding it back. No water issues as all the compartments have been bone dry as usual
Items I have checked:
-Boat is cleaned and detailed after each use in salt water so hull is smooth and clean, no growth or obstructions
-Heat soak likely not an issue as I have good water flow out the cooling lines and the lack of performance has been consistent throughout the day, regarless if the boat just started or has been running for over an hour.
-Intake and tunnel has factory sealant still in place, looks in great shape and no obstructions around the shaft or impeller (I haven't pulled the pump yet, this is only looking from the intake side
-Bucket on pump clears the opening at WOT, no issues there
-Weight in the boat is balanced with minimum weight up front, normally can hit 50-52 with 2 people, gear and full tank of gas
-I have gone through a tank or two of fuel and I have filled up from different locations so I'm thinking I'm ruling out bad fuel as an issue
I want to know what else I should look at to try and track it down. Like I said the boat overall is running fine, starts fine and has solid thrust, but the past few outings have felt "off" and feel its only running at about 90-95% of what it should be. This is what I plan on trying to do this week and upcoming weekend when I have time after work:
-Pulling the jet pump apart and pulling out the impeller and checking the impeller and bearings. Checking the rest of the tunnel to see if there are any other obstructions. Checking the wear ring, etc
-Checking oil levels, spark plugs, caps to the plugs, etc.
-Checking the throttle stop/cable
-Checking the air filter
-General checking of hoses, clamps, etc on the engine to make sure everything is tight.
I'm hoping it ends up being a smoking gun that something above is wrong and I can fix it and test immediately. But I want to cover my bases, so is there anything else specifically I should be looking for? I'm reasonably handy (more carpentry/construction skills as opposed to mechanical) but I'm confident to do a decent amount of work on these boats and engines given how simple their design and operation is so I'll take any suggestions and make a punch list to go through. Thanks for the help everyone!
Quick background:
