Billy Marlin
- Tallahassee, FL
- FSH Deluxe
Very busy day caulked under my console everywhere and realized all the locker lids were not tightening down.
2nd Bilge Install direct wired to battery with built in float switch
FYI I ran by hole saw in reverse as suggested by others!!!! Use blue tape as well before drilling!!
Tightened down my locker lids which were way too loose
Port Rear Compartment drain to motor
Found small amounts of water standing back here so adding these holes so the water can easily get down to the bilge.
Starboard Drain to motor
SeaDek Drainage
Had standing water in these phone holders so I drilled holes in each side so they can drain out
Caulk around the throttle want to make sure no water gets through
Put silicon around everything so it won't get down into my center console area.
Wire Caulking
Ignition Caulking
Expensive amp cover
Put rubber spacers below the amp so its not directly sitting on the white board. In case water gets on it the amp will be above it and to allow for air flow. Once it gets warmer might add a small computer fan to help with air flow.
Pictures do not show it well but the cover actually has an overhang for air to come up and I put air holes in the sides to allow for air movement. Its not completely covered
SeaDek Drainage
Wire Caulking
Ignition Caulking
Expensive amp cover
