Carrier Air handler tray leaking - only 9 years old....
My 9 year old carrier has a broken condensation tray....not happy (part under warranty, but labor to replace is not cheap....and of course I'm about to head out of the country on business, so I can't do anything myself!).
Really trying to figure out how the tray broke....I suspect the HVAC guys broke it.....can't imagine they break themselves!
Is this usual? How could it break on its own?
Seems suspicious to me - this happened shortly after the drain clogged and the drain tray overflowed because the float switch was installed incorrectly (wired wrong) - and this leaked through a cieling which had to be replaced. The company fixed the float and installed a different cutoff on the tray, and 2 weeks later...the internal air handler tray is cracked and leaking.....
Gym
Falmouth, MA (Cape Cod)
Is this the tray that sits under the air handle? Is it plastic or metal? I agree the repair guy probably tripped or kicked it accidentally and broke it but he will plead the 5th if asked.
Dean P
Chaparral
VRX
Never heard of a tray breaking. Did it crack at the nozzle? Could you 5200 it? Do you have pics?
This is the tray within the unit that has multiple drain outlets...one into the house drain, backup into the big tray below the unit.
They messed with the drain connections to the internal tray to add a sensor within it to alarm if the tray fills (drain is plugged). Then they also fixed the float on the big tray below to actually work.
Don't have any photos.....haven't had a chance to dig into it at all. They are saying the part is covered under warranty, but labor will be 400-800 depending on if they end up have to add refrigerant.
And of course I fly out of the country tomorrow! These things usually break while I'm out of the country!
