tdonoughue
- The Woodlands, TX 77381
Maybe after close inspection. Isn't that stuff cast though both on the tube and the plug? If it is I wonder if it will just break? The puzzling part is how did even get into that position. Not sure I could do that with mine if I tried..
Wife always says I'm stronger than I think I am.@Ozark yes you are correct. Maybe a 1 x 2 or something like that from underneath and a couple of good taps with light/heavy hammer may just pop it out. Probably put some silicone spray or something all over where the set tab is.
Must have been a lot of force to get it in there I would think.
Tried that. Wasn't successful.
In addition to pulling straight up and possibly breaking the plastic set tab should I worry about damaging anything else? I don't know how long it would take to get another cap. Might miss the whole season, but can't use the as is.
You really don't have much of a choice. Pick one of the methods recommended that you feel may work the best and give it a shot. See what happens. Or wait to see if you can get it into the dealer.
Left a VM with dealer a couple if days ago haven't heard back. Will try again.Have you consulted the dealer? I’m sure the dealer has dealt with this sort of thing before.
I think I would try to tap them back down, and then reverse your procedure when you installed them. All the water pressure is what has them lodged in the up position. If the water pressure couldn't blow them off, doubt you will be able to pull them out. I would tap them back down and then find a way to turn them counter clockwise, assuming you turned them clockwise when installing.
Dealer is about 45 minutes away. Thought of that. Left a msg with a specific tech, hope to hear back soon.How far is your dealer? If this was me, I'd just pull in with the boat in the afternoon and ask if one of their techs could "come out and quick give me some advice."
