drewkaree
- Central WI
No cutting!!
That's a bridge to be crossed when he can see both sides of that plastic piece that's causing problems.
If it's simply jammed in there, it might be able to be pushed into a position for removal, but if it's jammed in there, it's going to cause less damage to the cleanout port hose and lower fittings to carefully cut pieces out of the plastic ring until it can be destroyed inward toward the center of the ring to the point of removal.
