Cleanout plug full of water
motorboater
Gull Lake Chain, Nisswa, MN
One of my plugs always seems to fill with water. It is now harder to remove than the other plug even though I religiously remove them after each use/overnight, clean them and the tubes, and never use any sort of lubricant on them.
Do others have plugs filling with water as well? I had water in it when I disassembled it to install the TruLocks so I dont think I've created the problem. Suppose I'll need to check the seal on the bottom half.
Yup....water on the top of the plugs is normal. If your plug is hard to put in and take out, sounds like you need to order a plug repair kit. Link on this is in the FAQ.
One of mine ends up with water in it. I believe there is an o-ring on the release plugger that goes bad and lets water in, also the rubber skirt around the plug might go bad. Once I get aggreviated enough with water in my plug I will take it apart to inspect.
my one plug was an SOB to pull out.........THEN someone told me to twist the push button clockwise to tighten it up. I did this and the problem was solved... try it out and let me know
I get some water INSIDE the plug. I take mine apart every Winter and dry out to prevent water from freezing in there.
As Julian mentions, the Yamaha repair kit is not expensive, had the rubber seal/gasket, and the lower plug half. If it is filling with water easily, the seal/gasket is failing to do a good job. The I-ring leaks too, but it is minimal compared to the gasket. If it is hard to remove and it is clean, the ABS lower half is swelling and sticking. I have repaired these in the past by sanding down. I won't do that again. If I get a plug that fixed me any issues when clean and the neck seat is clean, I will replace the wear parts in a heartbeat...life is short, and a sticking plug is a blowout in the making.
Yup, water inside the plug itself is what I'm talking about. Have to order the repair kit I guess. Perhaps rotating the release knob a little further will help it release easier, thanks for the info @geiger41.
I get water in side my plugs too. So far it hasn't caused any issues. I did open them up once and dry them out. But so far no real problems.
That's what I do. Take them apart and store inside.
