- North Caldwell, NJ
Mike - check out post #3 https://jetboaters.net/threads/stereo-upgrade-help.15954/#post-274333 - which shows some of my wiring at the helm.I bought the same lights but in black. Mine did not come with screws. I was just wondering.
Where did you tap power from?
How did you positioned these lights? Did you wire them first externally in the driveway to figure out the best placement on the boat or did you just try to match the 242 Limited S location?
As far as the screws - I would use SS that fit and are probably not longer than 1". When drilling - the fit is critical, too tight - will crack the gel coat, too loose - won't hold.
My placement was done in the driveway - the location followed factory and then I tried to position the lights to give the strongest beam forward to help dock in the dark. Those lights are not super bright but I find them adequate/helpful around the docks.
