- Tranquility Base
- FSH Sport
I know this is an old thread, but I'm pretty sure this is incorrect - the DVSR (from what I have read) is literally there to allow you to charge multiple batteries as one. Yes, a multi-bank charger will charge multiple batteries with the DVSR "on"...but only using one bank, because the DVSR makes it look like multiple batteries = a single battery, not multiples. You are correct in that both/all batteries are being charged, just not independently - downstream batteries will be charged AFTER the upstream batteries are full, since electrically, the DVSR is basically turning multiple batteries into a bigger "pool", if that makes sense to you.
i.e. you don't have: Battery 1 @ 100 aH - Battery 2 @ 100 aH - Battery 3 @ 100aH
You DO have: Big Battery 1 @ 300 aH (which is the combined capacity of the 3 batteries to fill, thanks to the DVSR), and it essentially fills that pool, which extends the recharge timing since you'd be using a single bank instead of the 2/3 potential from the charger
The DVSR is there to isolate the start battery when the engine isn’t running so you will always have a fully charged start battery. Once you start the engines and the voltage on the start battery comes up to 13.2 volts, a decent state of charge, the DVSR will close the switch combining all batteries so the house batteries will charge. It should be noted that the positives to the engines are landed on the start battery and not the house battery.
The greatest amount of charge will be flowing to the battery with the lowest voltage, aka potential difference, relative to its fully charged resting voltage.
Having said the above, I discovered this year that if the voltage on the house battery comes up to or exceeds 13.2 volts, the DVSR will close the switch. I found this out when I replaced the lead acid house battery with a LiFePO battery who’s resting voltage is 13.6 volts.
My solution was to intercept the DVSR red wire and provide voltage to the DVSR manually via a rocker switch on the dash. in my case it keeps the LiFePO battery from trying to “charge” my AGM start battery due to the potential difference when the DVSR closes the switch due to the LiFePO‘s 13.6 resting voltage. The secondary aspect is that it allows each battery to charge separately.
My MinnKota charger has a manual equalizing charger (in addition to the automatic light equalization charge), and this is pretty important to maintain optimal battery performance for a flooded lead acid battery, but an equalization charge has to be applied to each battery individually. An equalization charge makes sure that all the cells are balanced, and that the electrolyte gets stirred to eliminate stratification of the electrolyte. During boating season you should probably run a manual equalization charge once a month. When I still had my flooded lead acid batteries I was just lifting the ground for the DVSR when I ran an equalization charge.
