PhatPat
- Limited S
@Julian - Thank you sir! I notice the very first sentence of this thread, that you started 7.5 years ago, is "First of all the reverse maneuver will not remove something wedged in the impeller". I need to read more carefully - sorry for making you repeat yourself.
@tdonoughue - Fair enough. I appreciate the feedback! And you are absolutely right - those 3 screws are in there really good. I see the shop manual specifies adding loctite to them when you install them, which is probably why. If someone were to remove them, they would be best to use a drill with a hex bit and push very hard so they don't strip the head, or at least use a socket wrench with a hex bit in it. Allen wrench won't cut it. And if you were to strip the head on one of those screws, you will probably snap off the screw extractor trying to get it out, but you still might get it out just enough to get some vice grips on it and turn it the rest of the way. I am speaking hypothetically, of course. ;-)
FWIW, I have taken off both my starboard and port grates before and re-installed them. I have probably over 50 hours on the boat since then and have never noticed any issues - no reduction in top speed and no intake tunnel cavitation (that I know of). I can definitely see the desire to try and smooth out their transition with some caulk or something. That might buy an extra mph...
