SCSTWG
- Syracuse, NY
Well, I failed to add the stringer line to the toolbox as I planned in the previous post and could have used it yesterday. We launched and as I backed away from the dock I could tell something was wrong. Difficult to describe, but engine was making an odd noise intermittently. Shut it down and checked the clean out ports and they were fine. Started back up and checked the pee holes. The front one (port engine) was blocked. Thanks to the forum I knew what was going on. I didn't have the weedeater line, but had some long tie wraps. The blockage was right near the discharge port, but I couldn't free it. Had to undo the hose clamp under the starboard rear seat and pull the hose off of the discharge port. Blockage was visible and in a few minutes had it cleared out. Looked like a little nest. Boat ran perfect the rest of the day. Stringer line is cut and had been placed with the boat gear so it will definitely make it to the boat on our next trip out.
