- Raleigh, NC 27614
- 242X E-Series
Not sure if this is something the new boats do, or if their digital gauges display the codes in "writing", but the older 230's use flash codes on the warning lights to send you a message. Here are the flash codes it can send:
01 No malfunction
13 Incorrect pickup coil signal
15 Incorrect engine temp sensor signal
18 Incorrect throttle position sensor signal
19 Incorrect battery voltage
23 Incorrect intake air temperature sensor signal
24 Incorrect cam position sensor signal
29 Incorrect intake air pressure sensor signal
48 Incorrect data transmission
54 Incorrect bypass valve motor signal
63 Incorrect intake air system signal
68 Malfunctioning No Wake sensor/switch
Error Codes
01 No malfunction
Error Codes
