Exhaust smoke/steam - more than usual
Ribs77
PNW
So there's always some steam/exhaust that I see when surfing, I know it's not a big deal, but today it seemed like there was kind of a lot more than usual.
The boat performed fine, I didn't get any temp alarms, pissers were pissing, etc... But it was a LOT, especially on the starboard side and especially toward the start of the session.
Any reason to be concerned? I ran the boat for probably 10 mins going from the wet slip to the end of the no wake zone, then killed engine and spent 10 mins setting up ballast before getting started.
Could the engine have completely cooled down in that time and then been under stress /burning oil or something? I changed oil before the start of the season and have put about 50-60 hours on since then.
Pic
Bonus pic of the rad wake that I have dialed
Smoke usually means burning of oil, maybe check dipstick to see if you are low.
Thats a great wave! Can you share your ballast/setup?
That looks like steam…. If the water temp has cooled down and or the air temp has cooled down as well. If you’re oil level is good and no alarms its normal.
I'll check the oil next time before heading out. Haven't had a chance since I saw this post. I also ran the boat on Saturday and it seemed like there wasn't as much steam. I hope it's steam... The air temp was colder when I got all the steam and warmer on Saturday when there was less. Water temp was about the same - around 72-74 degrees.
My ballast setup is 650 Fat Sac on the swim platform centered, about 200-250 (depending on how full I fill the bag) long skinny bag above the ski locker up into the bow, and 100 lbs of lead shoved in the back corner of the surf side compartment. Usually just one passenger on the surf side and driver. The wake I get from this on calm days is pretty solid, but I've needed to install the Lucky 13 cone and seal my intake tunnel to avoid cavitation with this kind of weight.
Checked the oil and it was just above the lower hole. I think that means it's within acceptable range.
My season will be ending in the next couple of weeks, so I might add a few ounces but then I'll be doing a full oil change and new plugs.
With that blowing into the face of whoever is back there, it should be quite easy to determine if it was oil, just from the smell.
Looks like steam, my latest increase was due to some funky new-to-me type of weeds that didn't stop water intake, but limited it enough to require pulling the boat to clear the intakes
I'd guess temps are your issue here, along with your cavitation issues
