fault codes
Grumpy
the last 2 times I have started my fsh190 the alarm sounds and gives me YDIS code: 1 and DBDS code: SPN 0 .. I drive it for about 5 minutes then shut it off and turn it back on and alarms stops and no codes.. has anybody else had this problem or know what the issue is
thanks
For my boat, a Diagnostic code of 0 = normal. There is no SPN 0 code, the lowest # it goes to on SPN is 105 (Intake Air Temp Sensor)
thanks
You ever figure this out? I’m having the same issue
thanks
Did this stop and clear on it's own eventually? My 190 is doing the same
Anyone figure this out? I have the same thing going on with my AR190
