If you want a bit more stability try shimming the back of your stabilizer. Go to the hardware store and get some half mm thick plastic sheet. Cut a little piece and drill a hole in it. The hole is for the rear screw of the stabilizer. The shim should be the width of the fuselage and go from just barely in front of the rear screw and go to the back of the stabilizer. You can try .5, 1.0 and 1.5mm thick. 1.5 will probably be too much, but you never know till you try it. The thicker the shim the more stable the setup will be and the more nose up the the foil will be trimmed for. At some point there will be too much lift. The excess lift will require more and more front foot pressure and you'll need to move your feet forward. At some point you'll need so much front foot pressure or forward placement that it will be difficult to start without pearling the board. It's all give and take; you have to find out what works best for you.Regarding Slingshot foils, has anyone tried the larger 48cm rear wing on the infinity 76? Looking for a little more pump and stability.
Different how? I ride mine most of the way back, but I still suck and haven’t ridden it much yet.I tried moving the mast to the most forward position today. Holy crap what s difference. Tried midway as well. Might settle on 3/4 to the front. Getting lots of slack rope, but every time i try to toss it....Wipe Out!
That’s some solid surfing!Here's some proof. My son doesnt ride the short rope. First try tonight with the mast forward....drop the rope and rides forever...
Ive been shown up again..
That looks amazing.Here's some proof. My son doesnt ride the short rope. First try tonight with the mast forward....drop the rope and rides forever...
I'm pretty certain it is the Time Code 57 which is the original Hover Glide wing.That’s some solid surfing!
What wing do you have? Seems plenty big based on him surfing like that.
I’ve got the gamma 68 and it feels like it would get plenty of power from the wake if I could just stay up.
I need to try this in the Infinity 76 I've been messing with... those guys have some for comparison videos that have been handy in advising folks.After watching some of those videos, I tries a double rope to get to the 2nd wave. Very cool. With a bigger wing it would be easy. Its so quiet way back there, but there is so much slop in the rope tension
Yes, any of the new Slingshot wings are still compatible with your fuselage and mast. The mounting system hasn't changed, just the lengths and sizes of the masts and wings.Can i get that wing on my fuselage? Or do I need a new stab wing and mast too? I would love to buy a whole new set up and dual foil with the kids.
Second session on the foil. Definitely a learning curve. I have very extensive wakeboarding experience, but little to no surfing experience. This is the first time I threw the rope. I crashed after about 10 seconds ropeless. Very fun. No ballast on a 2017 ar190.View attachment 127341
