For the battery experts… Lithium??
After several conversations with @FSH 210 Sport I ordered the Battle Born 100ah LiFePo battery and SmartShunt - I should have them by the end of next week. Like most, I was interested in some of the cheaper Amazon LiFePo’s but Dale was very deliberate in explaining the differences and I decided to spend the extra $$.
@FSH 210 Sport, @srf32 and everyone else could I get your thoughts on this?
My thinking is that the cheap BMS in the Redodo is cutting off charge and discharge at the upper voltage cutoff while the BattleBorn batteries may only cut off charge while leaving discharge active. I have experienced this with inexpensive BMS circuits that I have used in building LIon battery packs and with LifePo4 batteries that I have used in wheelchair projects.
One of the pair of AGM batteries that I installed in 2014 is showing 12.25 volts fully charged so I am thinking that it is time to replace them.
I am thinking that I may install a pair of low cost LifePo4 batteries to replace the AGMs. I want to tackle the LFP starter battery hurdle.
I have two thoughts on how to make this work.
1. Install 20A buck convertors after the factory rectifier regulators to prevent the stators from fully charging the batteries.
2. Replace the rectifier regulators with LFP compatible versions. Likelly MOSFET based rectifier regulators limited to a lower voltage.
Lots of good info in this thread https://jetboaters.net/threads/bad-...est-of-season-before-pulling-to-repair.29032/
This thread is interesting https://www.advrider.com/f/threads/lithium-batteries-mosfet-regulators-big-shunting-probs.1503976/
See my posts [HASH=536]#’s[/HASH] 14 & 15 in this thread.
To reiterate, I’ve been running heated 100Ah Battle Born batteries in my boat since early in 2022, so going into my third season with them. There are three trolling motor batteries for my trolling motor which is its own separate system, and one house battery. See my thread on this here; https://jetboaters.net/threads/conversion-to-lifepo-batteries.35834/page-3
In the scope of this thread I have had zero issues with the Battle Born house battery, it charges off of the OEM rectifier / regulator with zero issues. I think the greatest depth of discharge I’ve done on the BB house battery was around 20%, and since I have the Victron smart shunt I could watch how much current the alternators were putting into the BB house battery and watch the state of charge level climb as time passed. The highest rate of charge I’ve seen coming from the engines was 26 Amps combined, during the aforementioned charging on the water after a 20% discharge was 23 amps initially then held steady at 20 amps for sometime before tapering off, this was with the engines above 3500 rpm, at idle the charge rate was 13-14 amps combined. While I did not have the Victron smart shunt installed when my FLA battery was installed, the rate of re charging of the BB LFP battery is very fast and much faster than the FLA battery was. I base that on the voltage level of the FLA house battery as read from the connext screen while I was on the water after running the live well and electronics for most of the day then having to run the engines to bring the FLA battery up from low voltage to finish out the day before heading home and plugging in the chargers.
My understanding is that my TR-1 alternators are three phase AC and the rectifier is full wave, so as far as my 2020 model year TR-1 engines and their alternators are concerned, the marriage to the Battle Born LFP batteries is a good one. And as stated previously, our alternators are always at full output with excess voltage being shunted to ground, so there is no excess / damaging heating that can occur in our alternators as opposed to automotive style alternators. This is due to the fact our alternators have fixed magnetic fields (fixed flux density) on the rotor, or PMA permanent magnet alternators, and the rectifier regulator regulates the output by shunting excess output to ground, this is why the rectifier / regulator is always hot when the engines are running even when the batteries are fully charged, and why their mounting bases water cooled. Automotive style alternators use a variable magnetic field (flux density) VMA to regulate output, these alternators are capable of much greater output in a given size compared to a PMA, but most of these only have a duty cycle of 10% otherwise they will over heat and burn up. With low resistance of LFP batteries, the automotive style alternators and their regulators will charge at 100% output / duty cycle and will burn up. There are some automotive style alternators that can run at 100% duty cycle and others that have a thermocouple in the windings to roll back output when it gets too hot. This is where DC to DC chargers come into play, they are fed from the starter battery and will only allow a lower rate of charge to a LFP battery, this not only protects the 10% duty cycle automotive / VMA alternator it also extends the service life of the LFP battery by keeping the charge rate below the maximum charge rate of the LFP battery. This is what a lot of the Van Life folks do to charge their LFP batteries off of the vans alternators. Yes, a well designed BMS will cut off excessive charge rates to protect the battery, and if the charge rate is always too high the battery will not charge, and, just like keeping the depth of discharge at 80% or less will increase the service life of the LFP battery, so will keeping the charge rate at .25C (25% of the Ah rating) rather than charging at the maximum.50C.
I agree with your assessment that the Battle Born BMS is regulating as it should by not allowing the battery to be over charged but still allowing discharge.
Installing a device to make a cheap LFP battery work, to me, doesn‘t sound like a good idea. And as I have illustrated above, so far the BB house battery (as well as the trolling motor batteries) are performing well with the OEM Alternators and rec/reg’s so there is no need to install a different reg/rec.
NOTE: You do have to modify the DVSR to only be active while the engines are running or manually switch the DVSR (that’s how mine is currently set up) or the DVSR will stay closed due to the higher resting voltage of LFP batteries. This will keep the batteries in parallel and not isolate the start battery from house loads. If you have a lead acid start battery the LFP battery will charge that battery until the voltage drops to 12.7 which is when the LFP battery is essentially 90% discharged, and most likely will ruin the lead acid start battery. Recently one of our members with a 255XD installed two 100 Ah batteries for the house loads and has a FLA start battery I believe, could be an AGM, and he tapped off of one of the fuel pump positive leads to power the DVSR making it fully automatic with a “run” hot. I may switch over to that myself.
As far as having an LFP starter battery goes, I know that one member here is using Battle Born batteries for both starter and house with no issues since the starter draw is below the BMS cut offs. Having said that, Dakota Lithium has a group 24 starter battery rated at 1000 CCA that you could check out, I’m just not a fan of DL as they do not have tech csr’s that you can talk to, and they’ve committed an integrity violation by leading people to believe they are a North Dakota based company, they are not they are a Chinese based company. Also, if you watch the “Morgan’s on the move” YouTube video in my conversion to LiFePO batteries thread you’ll see that FLA batteries are better for starter battery applications, and that is why I stayed with an Interstate group 24 dual purpose AGM start battery.
Man that was a lot for a Sunday morning…
No pressure LOL! I am confident that the BB batteries will last you at least a decade if not 15 years with no trouble, and if you upgrade to a different boat in the future you will be able to take the LFP batteries and smart shunt with you to the new boat. And, the BB tech csr’s will be available by phone five days a week to answer any questions or resolve any issues.
So, I want to make a special note here, unlike other battery companies, both lead acid and LFP, Battle Born’s sales reps are the tech reps as well, so when folks call up to buy their batteries their sales reps are the ones that will line you up with the correct system, so no getting transferred to the tech department. Their tech csr’s are also very up to speed on the Victron Energy products and will help you to configure those devices in your system.
This was a three-part project that I finished off yesterday:
1- DVSR mod - clipped the red wire and spliced the non-voltage side to the port side fuel pump on Saturday
2- Victron SmartShunt install and Victron app for my phone - completed yesterday
3- Battle Born 100aH LiFePO4 install - completed yesterday
All three parts of the project went pretty smooth - many thanks to @FSH 210 Sport (Dale) for guidance through the battery buying phase and some invaluable feedback during the installation.
One advantage that I (and my lower back) noticed immediately was the difference in weight between my old house battery (Group 31 Odyssey Extreme - 77.8lbs) and the new LiFePO4 battery at 31lbs. My only complaint so far is that the Battle Born handle is an "optional" item that they charge $7 for on their website which seems like the oddest sales decision of all time for a battery that costs $925. They did offer to send me a couple for free after I sent an email but I already grabbed one.
I will be on the water this weekend and will report back to the group on how the battery performs from a discharge/charge standpoint.
I have the BB 100ah for my house batt as well, I is a freakin beast! I can run all my equipment, VHF, Chart plotter, livewell pump and 1000w amp + 10 speakers for nearly 12 hours or more at half volume. It was well worth the purchase price for me.
A quick timeline for this project:
Saturday: Unscrew DVSR from battery compartment wall, clip red wire, splice new wire on non-voltage side, remove gas tank floor panel, run non-voltage side wire along backside of engine compartment to port side fuel pump harness, splice non-voltage side wire into blue (hot) wire for fuel pump. There was some swearing involved as I hate projects but I considered the juice worth the squeeze in this instance.
Sunday: DVSR working as expected - no red light on when charging batteries in the warehouse - red light on when on the water with engines started. BUT........sucked the rear dock line into the port engine on a beautiful sunny day with no wind. There was a lot of swearing involved but at the end of the day the dock line was removed and no permanent damage. More info on this in a different thread.
Monday: Decided to take Monday and Tuesday off - sat at home on the couch, watched Dune part 2 for the second time and did some cleanup around the house. No swearing involved.
Tuesday: Temperature was in the low 80's but the warehouse where my boat is stored (in/out service) had to be 90. Installed SmartShunt and battery, rewired batteries according to SmartShunt instructions, tried to download Victron app for my phone but cellular service is bad in the warehouse, some swearing, went to Panera and bought a soda to use their free wifi to download the app, went back to boat and connected to SmartShunt and set up battery parameters in the app. A little swearing installed due to how hot it was and some running around that I had to do for drill bits and to download the Victron app.
All in all things went pretty well and I'm really impressed with the Victron app for my phone that will allow me to monitor exact voltage and charge/discharge characteristics of the LiFePO4 house battery and also the exact voltage info for my AGM start battery.
WiskyDan,
Glad this is all working out for you and a great pay off for all of the homework and sweat equity you put into this project! I’m sure you will have the same experience that @Dixemon has been having with his BB battery.
@Dixemon do you have the smart shunt as well? If so what have you seen in the way of SOC with all of those devices running, and how many charge amps are you seeing from the engines?
I had originally been helping a member here with a 2023 or 2024 255XD with how to make the dvsr work on a “run hot”, not an ignition hot, in the end he hooked up the dvsr feed to the fuel pump hot and reported back that all worked well so I was able to pass that information on to @WiskyDan who in turn found some excellent WAGO splices, perhaps WD will share those splices here.
I have been running my DVSR off of a rocker switch on the dash, but my intention is to make the mod to tie into the fuel pump hot to make it fully automatic going forward. I have forgotten to turn off the rocker switch a couple of times with no harm no foul, but I strive to put everything on fully automatic. @lazergeek you may find this interesting with tying into the fuel pump hot instead of the ignition hot and it seems it would be a very simple change over to use with the twin relays you installed for an ignition hot.
Big shout out to @WiskyDan for noticing that I had the Pueker number set incorrectly on my house battery smart shunt, mine was set at 1.09 and should have been 1.05.
My thinking here is that setting up the DVSR to a run hot is the most desirable way to configure the DVSR no matter what battery chemistry one has. This will keep the batteries isolated with engines off on the water, as well as keeping them isolated during charging / battery conditioning which is highly desirable to get the most out of one’s deep cycle house battery.
The other thing that at least @WiskyDan is going to be able to see with the smart shunt is how many amps are flowing into the house batteries with engines running and the SOC or state of charge will update accordingly as the engines run over time. My forecast is that you will see roughly 20-24 amps of charging from the engines while running at 3500 rpm and above if the LFP BB house battery gets down to 50% SOC.
Well done @WiskyDan ! You know have a set up that is fire and forget while on the water! Go forth and burneth the fuel and or float with confidence!
@FSH 210 Sport I have been watching this thread. Im not planning on changing my current setup with the ignition switches as its working well for me and the work is done to setup. The issue I foresee with the fuel pump is you have 2 fuel pumps, one for each motor so if you only run one motor for whatever reason you may not be charging so you would need to do something similar to what I did with the relays of you wanted to energize the DVSR regardless of which motor is running.
Right on… that is why I mentioned tying into your twin relay system which is working great for you!
Here's a snip of my memorial day weekend trips. from around 9am to about 4-6pm, average time at the sand bar 4-5 hours, I saw a drop to 86% SOC. This is with Stereo system running 30-70% volume, 1000w amp, 8x 6.5", 2x10" subs, MFD on, VHF on. phones charging ect.. I did not have the live well running. To be fair i would never have my stereo jamming while im fishing, it is usually off all together.
Haven't really payed any attention to the charging amps but i will be sure to next time out.
I'm guessing that tying the DVSR's Red Wire to the battery switches would isolate the batt's when the batt. switches are off but not when engines are off on the water but batt. switches are on?
I will post up some photos in one of the DVSR threads and include info on the Wago splices.
A broken clock is right twice per day. :)
Correct! One advantage to tying it to a run hot is that the DVSR opens when the voltage hits 12.7, this means that buss voltage if you will of the two batteries being tied together when the DVSR is closed has to decay from the 13.4 close point and possibly 14.4 fully charged level must drop to 12.7 with the batteries tied together before the DVSR opens. Basically that would mean that the start battery would help supply house loads until the DVSR opens.. its kind of splitting hairs with flooded lead acid batteries, but AGM batteries resting voltage is 12.8 compared to flooded lead acid‘s 12.5.
Those of you with the SmartShunt, can you post a pic of how you connected to the battery / mounted? It looks like you need to use a battery cable to connect instead of it connecting directly to the negative post which is how my generic shunt is connecting. Im thinking of upgrading my shunt as I only get current status, no logging and history like you guys are getting.
@FSH 210 Sport How long is your cable that runs to the house battery from the shunt? I assume you have the negative cable that connects to the start battery to the house battery, not running through the shunt correct?
Ill get a pick of mine when i get home. But to try and answer your question, The only negative lead that can go to the shunt is the battery you are trying to monitor. If you have multiple grounds jumping between the house and start batteries you wont get true data. This is why I ended up putting in a negative bus bar in my battery compartment to Isolate the house battery from the rest of the grounds.
The ground cable from the house battery - to the shunt is 12-18” long.
Yes! The ground that goes to the start battery is connected to the system minus side of the shunt, and is also tied to the main ground, as well as the other grounds that were connected to the - minus side of the house battery. If you look closely at the system minus you can see the house load grounds in the alligator flex behind the ground going to the start battery.
In this way, all current leaving or going into the house battery passes through the shunt which is all house loads. I have as tempted to run everything through the shunt initially so I could see starter amps as well as total charge current into both batteries, but in the end I decided it really didn’t matter.
@FSH 210 Sport I mounted the SmartShunt exactly like you did with the two red wires facing up but when I finished I was thinking that I should have mounted it 180 degrees different to protect them from getting wet or pushed on if I was moving stuff in/out of the battery compartment. Glad we're the same - now I'm not so worried. :)
@lazergeek I moved the three negative cables from my house battery to the "To system minus" connection and bought a new battery negative cable that I connected from my battery negative to the "To battery minus" connection. Make sure to check that all of the ends on your negative wires are large enough for the SmartShunt bolt to pass through. I had to run back to Napa for a different battery cable because the bolt was too big to pass through.
How did you determine what gauge wire to use for the new negative. I assume it has to be able to handle the full load from all 3 of your system negative wires going into the shunt. I have a 195S, it has the stock negative going to the battery and then a direct run for my amp, 4 gauge 100 amp fuse, also going to the battery. Trying to figure out what gauge I would need to go from the battery to shunt.
