Swimmingly
- Falls Lake, North Carolina
- FSH Sport
I'm in the middle of a dual bank battery charger project, which seems like a great time to address the very poor FM reception and music quality on my FSH. I noticed the FM reception is almost nonexistent inside a marina or anytime I get away from a main body of water (underway - not trailering). I traced the FM antennae and it seems to be an 18gauge black wire, just zipped tied in with the rest of the wiring harness! No wonder reception is so bad. Has anyone improved their FM reception or added a "real" antennae inside the console?
Then there's the general sound output. If I could find a plug-n-play speaker replacement or an easy amp upgrade, I'd spend the money. On Yamaha's website, they list this as an FSH accessory (available else where for less $$$, I'm sure):
JBL® Marine Amplifiers
It seems that amp could be crimped into the existing JBL stereo power/accessory switch, then just swap the RCA speaker jacks from the head unit into the amp...EZ - PZ. One "non plug-n-play" issue might be the amp will need its own power/ground wires from the battery terminals (since its running more amps than anything else under the console).
I doubt if just adding two upgraded speakers would do anything for the sound output, and "for sure" would do nothing for the FM reception.
Anyone have suggestions or experience to pass along on an FM antennae upgrade or a basic amp install (barely listen to music, but when I do, I'd like to hear "something")?
Thanks in advance.
Thanks in advance.
