2kwik4u
- Buffalo, NY
Can someone ELI5 me why LED lights are blocking the signal? Is it some sort of PWM in the lights to dim them from full brightness? I'm completely lost here.
*edit*
Answering my own question here.
Pulse Width Modulation is used to increase the current to the diodes, resulting in a brighter light for a given voltage. This is what causes the flicker you see through video recording (or more appropriately the aliasing you see). Some LED's have poor shielding circuitry, or generally poor circuitry to suppress this PWM frequency which can then overlap your garage door opening (30-300Mhz range). Ferrite beads on the supply lines can help reduce the interfering emissions, but not eliminate it.
Some links
Why PWM is used in bulbs in the first place: https://electronics.stackexchange.c...rol-leds-even-when-theyre-only-used-on-or-off
Why PWM messes with the garage door operation: How LED Lights Cause Interference With Your Garage Door Opener
What PWM is: https://www.analogictips.com/pulse-width-modulation-pwm/
*edit*
Some links
