DogDadDave
- KY
Has anyone seen this before? It's like fine plastic shavings and wipes off with no effort. I'm afraid it's gelcoat that was rubbed off by the bunks, but I'm unsure, since it's lightly scattered all over the bottom of the hull.
This boat is new this year and has only been launched maybe a dozen times. I always put the trailer in at least deep enough that the water is at or over the tops of the fenders.
I never come in hot and slam in to the trailer. Always float it gently until I touch the bunks then give it a little power to stop it moving before going the rest of the way with the winch. Most of the time we launch at a place where I can back the trailer parallel to the dock and just push the boat in place manually.
Saturday after launching the boat I noticed what looked like burned/melted streaks on the trailer bunk carpet (unfortunately I took no pictures). I checked to make sure there were no screws or other metal poking through. Without having more carpet material on hand I loaded the boat at the end of the day and noticed this when I got home.
Weather permitting, I plan on launching the boat this weekend and replacing the bunk carpet to start, then checking to make sure there are no deep gouges in the gel coat if the water is clear enough.
