jetboater4life
- Rochester, MN 55901
- X
Hello,
This thread is being ported over from Yamaha Jet Boaters • Login originally posted by @buckbuck I followed it pretty much to a tee. I did a few minor things differently as documented below.
1) Used 3m5200 to seal up the through hull cable, 2) used a red led vs blue, 3) used T-taps to tap into the starboard accessory wire (purple) and the ground wire from the start switch. The port doesn't have an accessory wire.
When the switch is in the upright/accessory position and the ladder is down the red light is on. When the ladder is up the light is off.
Here is the original thread posted on July 18th 2013 along with the original pictures + one I took. Many of the purchase links are dead since I bought these parts when the thread was started about 10 years ago. It would be great if someone could post new links to the products.
I want to credit tracerrx for the ideas, plans and materials for this mod. You can view his write up here.
viewtopic.php?f=44&t=46880
I had finally had enough with the 'Ladder Down Club'. I wanted out and was ready to burn the bridge. I am not going back thanks to tracerrx.
Here are some pictures from my install. I tested placement many times before final install.
Removing the magnet from the plastic enclosure was easy. I just pumped some silicone in the leg of the ladder and slipped the magnet up inside. Mounting the proximity switch was easy except I snapped one screw off. Silicone holds switch and seals cable. Ran a cable to the helm and tied into the 12v socket. My daughter suggested the placement of the LED in order that the operator would see the light before starting the engines and any crew member could also see it. This thing works great.
I highly recommend this mod for those of you that are ready to drop your membership of the 'Ladder Down Club'.
