Help!2018 YAMAHA 242 Communication Error - Keypad- Check keypad CAN.
tenl
hello:
My 2018 242SE get an Communication Error - Keypad- Check keypad CAN.
What is the problem?
Thanks
97153
I had this today. Turned everything off for a minute then started back up without issue.
I had that error several times last summer. Never figured exact cause, but I think it may have been related to low battery voltage. After I put the batteries on trickle charge a week, the message hasn’t appeared again.
According to that image, your house battery looks to be at 11 volts....which is dead. Likely your issue.
Charge two batteries today. I will try it tomorrow morning. thank you
the battery is 11.9V now i charge two batteries today. I will try it tomorrow morning and show the picture . thank you
FYI, not sure you know this, but 11.9 is "discharged"....so fingers crossed this is all you need to do! :winkingthumbsup"
State of ChargeSpecific GravityVoltage
12V6V
100%1.26512.76.3
75%1.22512.46.2
50%1.19012.26.1
25%1.15512.06.0
Discharged1.12011.96.0
