@help 07 AR230 HO - no power
tpa joe
My 07 AR230 HO Has no accessory power and the engines have no power. I tried a new charged battery and a jump box with no luck and still no accessory power. Any ideas or tips would be greatly appreciated.
There should be a big fuse on the wall of your battery compartment. Follow the red wires until you find it.....my bet is it is blown. WHY it is blown is a whole different discussion.....did you just connect the batteries? Perhaps crossed a wire? Or was it running fine and then this?
tpa joe
The area where the battery is being stored doesn’t seem to have a large fuse box area.
mark_m
Columbus, OH
If your engines dont work i would guess the small fuses in circular cover on the ecu as mentioned above
Have you connected/disconnected anything since the last time it ran
tpa joe
I checked the fuzes in both black caps under the engine bay. All fuses look good after pulling them. The battery was charged full two weeks ago and reinstalled. That said, the boat wasn't started or checked for power after the instal. Now even with a high power jump box I still have 0 power to the accessorize / engines.
captainhook
Southern Maryland
Limited
There is a fuse inline on the cable coming from the battery in the battery compartment. You would never know it is a fuse because it’s near impossible to see. It has a holder. Follow the line directly coming off of the battery and look for the holder to pop off the cap.
Look good or you checked them with a meter?
I'd check them with a meter and then double check your battery voltage and reconnect
I had battery cables crossed for a second earlier this year and blew both fuses in both ecu's
If the fuses are good and battery voltage is good then you need to start trouble shooting with a meter at the starter relay
Robo
Pa
Follow the cables and see where the electric stops with a meter see if have power at the starter main cable
tpa joe
Hidden fuse was good. Time to keep tinkering.
dgfreeze
Central Ohio
Did you clean your battery terminals? If not, I'd recommend taking them off, wire brushing them off, and reinstalling. Then if you still don't have power, it's time to take a 12V test light or multimeter and start tracking it down like that.
mark_m
Columbus, OH
Did you confirm all four fuses on the back of the engine compartment? Especially the x2 20 amp ones?
Battery itself could be DOA, maybe pull it and get it load tested / replaced if required?
mark_m
Columbus, OH
This feels like you don’t have your battery reinstall wired correctly
tpa joe
Battery ended up being bad. All the fuses are good because it was installed properly, no crossing of the lines. Now I have power but the engines will not actually start.
Does anyone know if the fuel pump kicks on with the keys in the accessory position or does the key need to be fully turned ?
mark_m
Columbus, OH
Check the switches beneath the cleanout plug hatch if it will not crank the engines. If they crank but don’t start then check the lanyard.
tpa joe
One of the switches at the cleanout plug area is stuck in the down position. Maybe I should just replace both of them. I should probably buy spark plugs as well.
Anyone know where to buy parts without spending a fortune.
Top Bottom
