Ajax
- St. Louis MO
- SX
Not stuck on water. Luckily close to marina. We idled in.
The following is for the 2009 AR210 which should be the same as the SX210Anyone on this great forum now the technical name for this part or better yet Yamaha part number. It's a 09 sx210.
No, very doubtful. Just not enough force even if the fins hit the bottom from the waves.My best guess is impact during previous ownership. Only other thing I can think of is I did have it beached yesterday, bow in, in soft sand. Stern was in 20 inches of water and we took some heavy wake. Would you guys think the stern dropping after wave could cause this?
Thanks for all the help with part number. And 200 is lowest price I've seen yet.
My bolts are still in place. Luckily both rods were saved. Thanks for lock rite tip.Oh wow. The same thing just happened to me last weekend. It is a nozzle deflector and before I realized it was broken, I bent my steering cable and reverse cable. I also had the old cobra fins. I know my problem started with one bolt falling out since it was missing although it is hard to say cause/effect.
Easy fix and just a couple of hundred. I ordered from partspak.com and they turned it around quickly.
When you reinstall the deflector use red loc-tite.
How quick did new deflector show up after ordered.Oh wow. The same thing just happened to me last weekend. It is a nozzle deflector and before I realized it was broken, I bent my steering cable and reverse cable. I also had the old cobra fins. I know my problem started with one bolt falling out since it was missing although it is hard to say cause/effect.
