AaronW
- Atlanta, Texas
Hello everyone I’m new to this forum and to jet boating, with that said I’ve searched over all these forums to help me out and I think I’m at the point of asking for help now... I’ve got a 2005 AR230 and last week I went to the lake with it, got it started (the starboard engine was alittle sluggish to start but finally did, I took it out for a quick spin after launching it and killed it before making it to shore. Maybe 20 minutes later my wife and kids were getting in and pushed me out into the deep I then tried starting the engines to only hear it try to start then went to clicking, tried the only engine and same thing happened to it also! While on the lake I tested quite a bit found blown fuses and replaced them but still nothing working. I’ve brought it home now and have been for a week solid every day done all the easy things to eliminate something simple, fuses, battery, all three kill switches I ohmed them out and they are working, ohmed the ignition switches and they are working, pulled the starter relay and I have 12.7 V from battery and 12.1 V to the starter on it so it’s working, I just spent all day pulling the starter motor out and tested it on a battery and I spins very good, I’ve inspected front and back of the impeller for obstructions or the impeller hitting the housing and it all was good, but tried turning the impeller shaft and couldn’t get it to spin either way... I’m at wits end at this point
