How do you keep your ski locker open,
Txbred
252SE
Just wondering how do you keep your ski locker open. I've heard some on here(not this particular model) have hydraulic arms. What I've been using is a 15" peice of plastic pex pipe to prop it open if not it just slams shut. Just seems like I'm missing some thing.
RobbieO
Sacramento River Delta
212SE
Is there a place for the gas struts to mount? Maybe they forgot to install?
RobbieO
212SE
Txbred
252SE
My thoughts exactly. So I'm thinking that I'm missing one. It's hard for me to believe that they want you to hold it open with one arm while bending over to get things out with the other. Any one with a 252 SE that can confirm? I might have to make a call tomorrow.
Crob83
Indianapolis, IN
AR195
Ya man that's not right. On my 2018 195 it stays open until you shut it
Txbred
252SE
Did you have a gas or hydraulic arm on it?
OB WI
Madison, WI
No arm. It’s in the hinges I believe. Mine stays open on our AR250. Log it with the dealer for warranty.
Txbred
252SE
When I first got it, I noticed the screws on one of the hinges was almost stripping out of the door so I took it off and it was really tight to where I could barley close with my hands. So I tried to loosen it and the hinge pin broke, it was on that tight, but it did loosen it up so I just put it back on. So know you got me thinking that it was supposed to be tight to keep the door open but like I said the screw was starting to strip out the door to where I didn't feel comfortable leaving it that way.
swatski
North Caldwell, NJ
Older boats had a strut and it works well albeit many of us found it necessary to adjust the attachment sites for better operation.
Looks like no arm/strut in your model, only the (expensive) hinges:
I would think the best bet maybe to replace those sh..ty Yamaha screws with SS bolts, tightened as needed.
deubank1776
Ohio
252SD
My 252SD Ski locker does not stay open by its self either.
deubank1776
Ohio
252SD
How do you keep it open while unloading?
Good question… havent had it on the water yet. I would probably just use my shoulder and lift things out?
RobbieO
212SE
Sounds like another modification forthcoming. I would find a way to add the struts if it were me.
deubank1776
Ohio
252SD
You know I dont know about a strut. It would get in the way of unloading from the front or back. I would rather install flushed hinges, much like the ones on the compartments on the newer yamahas
Txbred
252SE
I'm under the impression that they're friction hinges, which makes sense now. I guess the one I had might have been to tight to open and close to where the screws were stipping out.
Txbred
252SE
I did the shoulder thing and it's a pain in the a$$. I would prop it open with my grill if I had to dive in there to get something or have some one hold it open.
deubank1776
Ohio
252SD
Do you have pictures of the hinges? Just so i can have a look?
