Betik
- Frisco, TX
- SX
I see that shopyamaha.com has one for $195. Is that overly expensive ?
You have to go to "Yamaha Accessories" not parts...should find it then....under "covers"Will do. I am calling yamaha sports plaza tomorrow because I could not find bow cover on their online inventory.
You are quite handy!Finally installed
I drilled a small hole first. Then reversed drilled about 2mm with a wider drill bit. Out of 14 holes I chipped the coat on 4 of them and forgot to reverse the drill on the wide drill on 2 holes. As a result those 2 hole where too wide for the screw. So I filled them with 5200 and put the screw. I will know 5 day later if they are going to hold up or not.
On the rest of the hole I just put some silicone to seal them.
I also cut a foam for the anchor compartment, so I can eliminate water intake from there too.
Looks good, where did you order your cover from?Finally installed
Yep, Yamaha bow and cockpit covers are pretty well designed. The bow part has a flap in the middle that snaps under the middle portion of the windshield, there is essentially no water intrusion.My Glastron came with a snap-on cover already installed, and this summer when I take the boat down to Halifax harbour (vs the lake we live on) to spin around the basin and out towards Chebucto Head, I was planning on leaving the foc'sle cover on. Mostly as a wind break. I'm driving a a GT187 bow-rider, so the open bow area results in a lot of wind through the center channel between the seats, and when I tried it on a cool day last summer, leaving the foc'sle cover on made a huge difference in comfort.
Additionally, it gives space for additional storage that is out of the way of the cockpit, and out of the sun, so I will probably tuck the cooler up there. Also, if one of the kids needs to get out of the sun, the could crawl in and put their head down on the front seats....one factor though is that I will be keeping a 'tiny anchor' in my cockpit area for emergency use as it'll take an extra minute or so to dig out the other anchor in the bow compartment because I'll have to un-snap and move stuff to get to it.
I had not considered the 'wave over the bow' as a factor until reading this thread, since I have not taken the boat out into deep water where significant wave action would be a concern, but I will keep it in mind if I do take it out that far.
One point about the install of the bow cover on the Glastron is that the segment of the cover that passes by the window/opening actually snaps to the underside of the window frame, giving a better seal and preventing water from coming over the top and in. I'm not sure how your Yamaha boat windows are configured, or if the cover has the extra 'tab' that would enable this or not.
Once upon a time I installed a snap-on cover on the back of my old pickup truck. Based on my experience with that, I'd personally be very reticent about doing it again on my own. I had a 'negative' experience with the durability of the screw-in snaps. Good to see that it's worked out well for you!
NS
@Betik Oh, I can relate. But it does get easier!I really hate drilling. Very stressful holes on your boat.
Let me know if you need any extra pictures or measurements, different angles etc., just PM me and I can text or email.@swatski I am definitely putting 5200 on the trim tab holes. I will probably read your threat like 5 more times before I start. I will do it when open the bilge for the back up pump installation.
OMG, ROTF@Betik, if you mount one of these at the right spot, it will shield the anchor locker and you won't need the foam.
