- Raleigh, NC 27614
- 242X E-Series
One small part of the overall video was a reference to how much water is being pulled from Lake Mead. It wasn't said in reference to the climate crisis, it was simply a statement on supply vs demand on the Lake. Clearly dought conditions are the primary factor for lake levels dropping. I didn't post this video to discuss climate change though, it was interesting to see the Higgins boat uncovered and the satellite image of lake levels.Calling overuse of a man made reservoir a "climate crisis" is a big disingenuous.
Read a good article about a Mississippi pipeline. Easier engineering than the Alaska pipeline. No leak problems, it's water. Would fill Powell in less than a year. Mead in year 2. Any giving time of the year there is a flood issue on the Mississippi river. Seems like a no brainer considering how much food is produced from the Colorado. I fly over mead weekly...it's unreal how much water is gone!!
I'm not sure it is primarily a CA problem. CA has more senior water rights to the Colorado River than either NV or AZ. Here is an article that talks about how cuts will mostly effect NV and AZ.
I suspect that if a plan is reached it likely will be funded by the three states and the federal government. It was ludacris to believe that the dessert would make a good area for agriculture.
Interesting article yesterday on Israel. They plan to desalinate seawater from the Mediterranean and pump it into the Sea of Galilee which is actually a freshwater lake.
Jim
There’s a few other states out here you know!Gotta say I disagree. Sounds like a colossal waste of money and bailout to CA. Seems to me the no brainer is to tell CA they're gonna need to use desalinated water for agricultural uses. They've got all the money, shouldn't be a problem for them. I'm sure they'll fire up some new clean energy to power it all too.
