veedubtek
- Punta Gorda, FL
- Scout
- Other
2nd week in a row I've tried to install my stereo system and failed because I didn't plan something well enough, or simply forgot something (boat stays at the camper, an hour away).
So. The stock Jensen HU only has one low level amp output, and I'm not a fan of splitting the signal (which I assume is already absolute crap because Jensen), so I ordered a new Kenwood unit. Well, much like everything else Yamaha has done so well on these FSH's, the hole for the radio was cut out by a blind man. After a case of beer. With a butter knife. And both hands tied behind his back.
Back to the Jensen. I haven't measured, but I just assume it's probably putting out less than .5v on the pre-outs, and I need to supply 2 amps. So, I was going to get a splitter and 2 line drivers (or just one LD and split afterwards, haven't found the specs yet) - looking at these-
https://www.amazon.com/Peripheral-PAC-LD10-Driver-Booster/dp/B003LWV77Y
Any experience or better suggestions? I'd get a piece of starboard and cut a DIN sized hole myself to install the radio, I just don't trust my cutting skills that much and can't seem to find a pre-cut piece.
