Multiple Drain Plug Lights
Ryland
Altamont MO
So I have a 2015 212x and I'm wanting to install brass drain plugs on the outside of my jet nozzles so I can install 2 drain plug lights. Has anyone tried this yet?
Never seen that done. Why wouldn't you just install standard transom mount LED lights....the install would be simpler and less chance of leaks.
Do you have a link to the Transom mount lights you're talking about?
