vesder21
- Cleveland Ohio
- FSH Sport
ok, that was super helpful. I will order the 6-circ with cover and the negative. thanks!!!
I have not tried surfing or wakeboarding with tabs yet, just lots of cruising. Waiting for the water to warm up. Just about there.Great info to help with the install . @Markwest Curious if you have been out surfing with the trim tabs and how they affect surfing ?
Well, I finally have everything arriving this week to do the installation. I thought I asked this before, but with the existing "House" switch, was there just no room to get the 1/0 cable in there onto the lug? I've purchased an extra switch, but it's going to take some time to arrive.I used all 20ft that I ordered. There is probably an extra foot or two service loop under the helm. I shortened about 1.5ft of black from the battery compartment because the route was so direct since no fuse.
currently on vacation so haven’t had time to research the switching option but I am thinking a single cut off for that route as well. Currently it is live to the helm. Little worried about the phantom draw the actuator controller will put on the house battery but it should be minimal in sleep mode.
The 1/0 wag wire is very large. Not sure I needed all the amp capacity at the helm but I also don’t want to have to run more in the future. I think 4AWG would have been fine with my current plans and much more manageable with current stock switching.
I do not have anything wired to pin 7. Works fine. I do have the auto leveling controller.Many thanks to @Markwest for the awesome install instructions. I handed the instructions to the service guys at my marina who installed them for me and they were impressed with the level of detail.
I had my boat out for the first time this season on Sunday and the tabs kept retracting every minute or two. After chatting with Lectrotab today, they told me that terminal 7 has to have 12v from one of the ignition switches while underway or else the controller thinks that the ignition is off and will keep retracting. I saw mention of not putting 12v on the terminal 7 in the install manual and am wondering how this works OK on other boats but not on mine?
Does it matter which ignition switch supplies the 12v to terminal 7? Is there a better option than the ignition switch?
Great install...Btw, is that plastic on your bunks?Tabs installed, electrics should arrive tomorrow and I can poke at it over the next couple evenings.
Somehow the starboard tab ended up 1/8” lower than port, despite numerous pre-fittings. Can’t imagine it’ll cause a problem but it’ll annoy me for as long as I own the boat
No plastic, just absurd quantities of dust. The joys of living more than a mile off of paved roads.Great install...Btw, is that plastic on your bunks?
No, on your trailer bunks. Looks like they are lined in plastic.No plastic, just absurd quantities of dust. The joys of living more than a mile off of paved roads.
Huh. It’s just the usual bunk carpet, trailer is 100% stock (other than obligatory bow roller replacement).No, on your trailer bunks. Looks like they are lined in plastic.
I was going back and forth on this for weeks and finally bought bus bars; I knew I’d be kicking myself if I left things a mess in the battery area. By going that route, there will be enough room on the House switch to run 0/1 from the House battery to the switch and from the switch to the bus, and every wire currently on the House switch will move to the bus bar. It’ll make things cleaner and easier to manage connectivity to the battery.@Quad - I am watching what @Markwest and @Neutron do. Past postings by @swatski too.
I started diagraming out the electrical. Below is as far as I got. I hope to do more in the next week. I won't be able to start until after Easter.
Ahhh......that’s what it is. Using terminal 7 is an option on the ALC-1 controller but it’s mandatory on the the MLC-1 (manual version) that I have. Mystery solved, thank you.![]()
My plan is to take the approach @Troch1 suggested - using PosiTap connectors on the yellow lead off of the ignition key. On E-Series boats this means tabs won't retract until I actually turn the ignition key off (not just turning the engines off). I am comfortable with this, as I am more interested in ensuring the tabs are retracted when I shut things down. For circuit protection purposes, I am installing a 1A inline fuse between the ignition key and the trim tab controller.Thanks @Markwest your directions made it so easy I opened the lectrotab instructIons to see if there was anything in there that could contribute to help then just threw it to the side . The only questionable items for my model 2017 XE was the location of the MLC-1 control panel and how to wire terminal 7 . The dash board layout is different so I ended up mounting it on the grey pad just to the left of the knob due to the molded pattern that is directly above the knob. For now I didn’t hook terminal 7 to the ignition switch it looked very difficult to reach the wires due to the amp board that I have mounted, but in the future I may look into removing the cup holder to get access to the wires. For my set up I have an on off switch to the 0 gauge wire that feeds power to everything that’s hooked up under the dash. As I sit in float mode the MLC-1 stays lit up but like others have mentioned there is probably minimal power consumption. Terminal 7 is hooked to the fuse holder under the dash the benefit is that when leaving the boat stored now I will have a visual that the switch is left on that feeds power to all the amps and electronics from the led indicator light on the MLC-1.
