anmut
- 212S
Just tried mine out and yes they are very sensitive I would bet that they could be even smaller for better range of use and less sensitivity I only go into the fist two lights . They are typically used on outboard motors that get a large bow rise. The jet drives are very loose in the tail end the way the jet thrust propels the boat the slightest bit of engagement allows the nose to drop most out board drives have fins that would create more resistance to the pivot being created . It would be great to see one with about 40% less surface area to see how they perform mine are 9 1/4 x 14 1/2, As others have noted great for choppy water It has also changed the shape of the wake Im very curios to see how its changed when launching wake to wake jumps waiting for warmer water.
The stock set up had a tendency to leave choppy water at the heel side lip for a goofy rider with the tabs we should have the ability to shape the wake better. In the picture below for what ever scenario we had that day left the wake perfect for jumping clean hard lip at the take off fluffy soft water for the landing. This was my secondary reason for getting the tabs first was choppy water smoother ride second quick wake shaping ability. This combined with the ballast should be interesting and fun for this season.
For the mounting location the dash boards are all different shapes I liked it just in front of the joystick knob but the 2017 x dash doesn't allow it to sit flat there so it was mounted on the grey pad and its very easy to use while underway.
We need lots of pictures of how these shape the wake for boarding and/or surfing. VERY interested in how this works out for you!
