HangOutdoors
- Royal Oak, MI
Why would you? What are you trying to gain?
I installed per the instructions and that gave me a about a half inch from actuator to the wakewedge when installed. I would think going higher with the trim tabs (say an inch) it would cause the actuator location to be pushed more rearward and would cause interference with the wedge. Won’t be around the boat for another week so can’t take the measurement right now.Great writeup! I can't tell if it was in the Google doc because some of the pictures are truncating weird at the page breaks, but did you measure out the location for the actuator installation? I am interested in how many inches back from the farthest point on the stern you went, so that I can consider a wakewedge in the future.
I don't really have a specific reason. Yes, I think they are less likely to be damaged if they are tucked up further, but maybe it would also keep an inexperienced user from easily over-deploying them and stuffing the bow. I just think, since we are still in the first five of years of practical application of these particular tabs, the way Swatski did it might not be the only way. I'm curious if there would be drawbacks to making the full retract position a little more retracted. The only limiting factor I can foresee right now would be contact between the tab and the actuator or the bottom of the swimdeck and the actuator; Or for those who still wish to use a wakewedge, it may push the upper actuator mounting point far enough aft that it interferes with the wedge or it may push the steep angle of the pivot between the actuator and the tab over the edge.
@swatski I noticed you routed your power under the fuel hatch going diagonal to the helm. I tried to remove the 4 x 6mm hex bolts but they were not budging - any hints on how to get this hatch off without first breaking each of the bolts/drilling them out and replacing them?
Great points. Personally, I'm planning to take the long route just to have visibility and potential access to them in the future in the engine bay.Like @swatski said, some PB blaster. In addition to that, use something like these two things if you have a compressor and an air chisel (another reason to buy tools? I'm in!):
Pneumatic smoothing hammer bits You're not trying to beat them out of the hole, you're simply using them to help get that PB Blaster into those hidden areas just a little faster.
Pneumatic hammer bolt breaker This isn't used like an impact socket or impact gun, you use to to apply hammer blows around the bolt for the same reason as the smoothing hammer bits - jiggle the PB Blaster into the dark regions of the threads and other rusty areas that are impeding your removal of said bolts.
There are risks to using tools such as these, but those bolts CAN be removed. Consider too, that they may have some thread locker on them, and some heat applied to the bolts may help as well.
I know all this is too late, but maybe someone else might find it useful.
Looks great!I think I corrected all the picture format issues. All pictures should be visible. I also added a general usage section as people have asked questions about how they actually work when installed. If you see more stuff feel free to add comments and point them out.
I used all 20ft that I ordered. There is probably an extra foot or two service loop under the helm. I shortened about 1.5ft of black from the battery compartment because the route was so direct since no fuse.Looks great!
It was sobering to see just how thick that 1/0 wire is on page 43!
Did you determine a switching option or is that whole branch of live all the time now? I am considering just installing a single switch for that branch.
Also, since you took the "long path", how much wire did you have left over all said and done? Deliberating 20' vs 25'.
Thanks again, this write up is amazing.
I get the same travel 2” and out of the water it returns to neutral when it detects no motion. I think you are good@Markwest , Great installation instructions.... crazy helpful!! I just completed my install and wiring but not sure i did wiring correct. I have a '16 242 LS and the manual controller. First issue is I may have connected to power incorrectly. On the controller I connected position 1 and 2 to the + and - straight to the battery. When I engage the actuators, they only open up about 1.5" - 2" at most. Is that the max? Also, once they are extended after about 2-3 minutes they retract completely. Fairly sure that is not normal so any suggestions on what I did wrong would be greatly appreciated.
You need to connect to a switched source of power as well as your constant 12v. You are witnessing the auto retract feature on ignition off. The 2 inch actuator stroke is the full travel of a short actuator.@Markwest , Great installation instructions.... crazy helpful!! I just completed my install and wiring but not sure i did wiring correct. I have a '16 242 LS and the manual controller. First issue is I may have connected to power incorrectly. On the controller I connected position 1 and 2 to the + and - straight to the battery. When I engage the actuators, they only open up about 1.5" - 2" at most. Is that the max? Also, once they are extended after about 2-3 minutes they retract completely. Fairly sure that is not normal so any suggestions on what I did wrong would be greatly appreciated.
Thanks for the info, appreciate it. On my ignition switch, which wire do I tap into? Here is a pic of the back side. In the pic, the red and yellow at the very top is the toggle switch for the blower. Wiring for ignition keys (2) is right below that.You need to connect to a switched source of power as well as your constant 12v. You are witnessing the auto retract feature on ignition off. The 2 inch actuator stroke is the full travel of a short actuator.
Yellow/red from one of the lower bundles should work for youThanks for the info, appreciate it. On my ignition switch, which wire do I tap into? Here is a pic of the back side. In the pic, the red and yellow at the very top is the toggle switch for the blower. Wiring for ignition keys (2) is right below that. View attachment 145474
First off, OUTSTANDING write up so thanks!
Since this will be my first install and I would like to future proof and install a fuse block to make hooking up electronics easier in the future (like a spreader light, radio, FELL MOB, maybe more speakers or amp, etc...) @Markwest My question is what's the difference in the fuse blocks and the one with a "negative" or "split" vs. the one you reference that does not have the negative?
EXAMPLE: Circ with cover vs. 12 circle with split and negative???
Which should I purchase as there are a lot of choices and thanks in advance!
