JasonSchoenrock
- North Carolina - Lake Norman
- Limited S
I finally got around to doing my trash can modification and thought I'd share here. My plan was to use a standard kitchen size trash can in the tray in the head storage area under the port side dash board. The trash can I got fits in the channel without moving the table, which I also store there.
So here's how it worked:
First, make sure I have all the equipment I need (forgot a tape measure, so had have my helper bring me one):
Here is the before picture:
Next was to mark the spot to cut the rubber stuff.. This was the scariest part of the whole project. One thing I did was to make sure the whole would be completely underneath in case I ever decided on 'undo' the job and order a new piece to cover it up. My idea of a back-out plan..
Cutting through was very tedious and I'd recommend using a sharper razor and only putting one line through. Trying to do multiple cuts created some loose edges that had to be cleaned up. The loose piece came up pretty easily with a scraper. The bowl was what I had that gave me a little extra diameter to give a little bit of a fit look. GooGone wipes took care of the left over glue.
Next was marking, taping and cutting... I used a 3 1/2" hole saw which was slightly large for the Yamaha cup holder, but the 3 1/4" was too small. I used a small drill bit first to get the hole started, then used the hole saw with a Dewalt right-angle driver. Pro-tip: let the hole saw do the work and keep it level so it doesn't bind up and rip the drill out of your hand. Fortunately I figured this out in my garage before trying it on the real thing.
I decided to cut the inside piece from the inside:
Finally, just cleaned up the edges, pre-drill holes for the screws on the plastic part and install the cup holder.
Finished product (cup holder also added):
The alignment of the holder to the trash can is not spot on, so I may add a bit of PVC or corrugated 3" tubing to help the trash get to the right place, but going to see how it works for a while first. Would love feedback from the group on this mod..
