New Freshwater Washdown under Helm
I know You know
South Florida
So I want to install a fresh water wash down on my 210 FSH and I have decided that the compartment under the helm would be ideal (we do not use a portable head on our boat) especially with weight distribution. Looking for ideas and or suggestions either Pro or Con. Thanks,
subysti
east Longmeadow Mass
I'm in the process of building my own fresh water wash down with a 10 Gallon tank. I will post more when I'm done.
Liveto99
New York Hudson Valley
47BE9A02-03A1-405B-B4D5-EC2059E7BC55.png This would be my suggestion.
I don’t know how to post a link. Here is a pic of the Amazon page.
HABANEROTE
Did you ended up doing this?
TommyB
Ocean City, MD
Has anyone used the Rinse Kit Portable Shower or the like? Curious if it has enough pressure and volume to successfully flush salt water. Thanks.
Emptytemples
Easton, PA & Ocean City, MD
Has anyone added freshwater system yet to boat that doesn't have it? I asked a dealer what it would cost me to add to a new AR and they said they would have to speak to service, they have never attempted this and would get back to me. It shouldn't be that big of a deal but I understand that these boats aren't really customizable and dealers aren't used to adding. Would like to add to mine eventually for washing sandy feet, chairs, toys etc.
Tranquility Base
Which AR?
I see that some of the 25’ boats have a fresh water shower, since the hulls are basically the same I’d imagine adding a freshwater shower / wash down would be relatively easy. Look at your storage areas and measure them, then check out West Marine for water tanks that will fit and you’ll be on your way, perhaps even a bladder could be used. Then it’s just a matter of mounting a water pump and plumbing it to your fresh water shower head and the tank. Youll want to install a fresh water inlet to fill that tank and a vent, the vent will be your full indicator when you fill it.
Yeah it will be a little bit of work but it should be a totally doable project. These boats are very customizable!
VitaminSea
Central FL
There are some write ups on the site, however from what I recall there was no “kit”. You have to determine where you want to mount the tank and then let that determine your tank size and go from there.
I went with a big kahuna shower, and after 1 season decided to convert it to more of a permanent install, routing the wand to a concealed holder on the swim platform.
The 4.7Gallon size fits nicely in the starboard aft storage compartment, and I left enough slack in all the lines to allow it to slide forward for when it’s time to fill it, removing the need to run a fill line.
Here’s the transom shower head I purchased
subysti
I did a write up about adding it to my AR240 many years ago. just do a search.
subysti
Marvin willis
Morehead city nc
I did one too on my ar240. It’s pretty easy. And mine has better water pressure than my house does. The only thing I haven’t done is move the switch to the dash. But i don’t use it enough that it’s not a priority.
Cambo
Long Island
In that link above in post #12 I showed my set up as well I use it every time the best part is that I use hot water. Also use it to wash the dogs after a day in the salt water. Adds 5 minutes to the prep time before leaving the drive way.
Tranquility Base
I like the hot water….Since Im in fresh water and I have a raw water wash down, I looked at trying to figure out a way to capture / divert the cooling water outlet from an engine to fill an onboard tank, or put in a small electric water heater, or let the hot cooling water be the heat source for a hot water tank, but there just isn’t enough room anywhere to put the tank.
When I think I’m going to want a warm shower in the evening because the lake water is still cold I use my solar shower, I’ve had this thing for almost 20 years, it gets the job done. I suppose I could put in a three way diverter valve and add the hot cooling water to a partially filled solar shower to get warm/hot water “on demand“
Or one of these…
I like this one, as long as one could use a 1 pound cylinder for the gas supply, and I have my own water supply. The first two have their own water pumps.
zipper
Boston Whaler
lazergeek
South Florida
Or one of these…
Re Route one of your pissers to fill your tank with either a diverter valve or have overflow for the tank run back to the pisser outlet so you dont have to even think about it. Its will always be full of warm water from the engine.
Tranquility Base
Brilliant! I didn’t even consider that water!
I would probably just use it to fill the solar shower bag.…. I did quite a bit of searching to find a tank that would fit in the boat somewhere, thought the aft bilge would be a good spot, just not enough room for a decent size tank. I may have to revisit this idea and possibly just fab up my own tank and use a diverter valve on the suction side of the raw water wash down pump 🤔. Having that “hot” water during the shoulder seasons would be great instead of the 42° lake water. And, the pisser water isn’t too hot like the cooling water outlet water would be.
lazergeek
South Florida
I was thinking about places I could stash a colapsable water bladder to for mine to free up my livewell. I was thinking possibly behind the fiish box up front but not sure I could get enough gallons to make it worth the while or Rear bildge would be good too. Im wanting about 20 gallons.
Tranquility Base
I think either the rear bilge, or in between the engines. The bladder is probably the best way to go to be able to use the available space. I’m partial to the aft bilge to put some weight back there to get the deck slanted that way to make water on the deck flow to the aft part of the deck which would make washing the deck at sea better.
