swatski
- North Caldwell, NJ
The L13 would help with hole shot and you would be able to pop on plane with heavier loads no doubt, provided well sealed pump and OEM impeller in perfect shape and factory pitch (albeit I have seen those to be off even new, too, with individual blades not lining up exactly the same on the trailing edge - relatively easy to check that on a flat bench).I just installed my R-S last week. It's great!!! The knob is much easier to feel and control than push buttons especially in choppy/rough water. You don't really have to look for it. Just feel and turn slowly and the the speed increases/decreased smoothly. It's accurate to .01 MPH. I have not found any problems in my initial test runs. I am still working out the ballast situation to get the perfect balance for the wave. I have a 2013 AR190. I was originally told to use 1200lbs in a certain configuration. This did not work as the boat would not plane and the engine was working way too hard. I was than told by the same person that 1200 was a mistake and I should drop to 600 total. That's was unfortunate because I wasted several hundred dollars on 600lbs of ballast bags I will never need. I plan to go out tomorrow and rig up the system to see how it goes. I also bought and installed the new JBP TVW. First test was ok. I think I have to tweak it a bit. Will see how everything works together. Fingers crossed.
I am also thinking of getting an L13 based on all the comments I have read here. Will consider this after my test runs and see if I still need an upgrade.
On another unrelated note, I hope someone can help with my Monster wakeboard rack not staying in place. I have the rings inside to take up the space but it keeps spinning on the Yamaha tower. I have it as tight as it can possible be (there is a space between the connector rings) and it still spins. It is mounted on a vertical post and after some time the back of the boards are facing into the boat (it swings/rotates horizontally). I have put electrical tape on the post but that actually made the situation worse. Any guidance/help would be appreciated.
Pictures of the rack in question would help. I find that the Monster rack that Yamaha uses (XTP version) is great, the locking pin may be a little hard to pull sometimes but just lifting the forks/load a tad removes that issue.
