TOGA
- Chattanooga, TN
- SX
2020 has been a dumpster fire no doubt caused by Carol Baskin.
Truck blew up. Broke friends master craft Friday before Memorial Day, and today my starboard drive decided to go south.
Need some help determine what’s going on and if it’s something I can fix or if I need to get it to a shop.
Started day off rescuing a 30’ sailboat off the shore and towing them back to their slip a couple miles up river.
dropped them off and started motoring up river. Lots of debris in water. One jet starts shuddering. Shut em down and pull clean out plug. Nothing in there.
start motoring again and it does it again. Check again. No debris but find a metal shaving.
start engine and let it idle. Fine for a while then a big think noise.
pull both plugs and compare play on shafts. Port is solid with no movement. Starboard has noticeable play.
Idled back to dock with port engine.
I have never torn into the drives on these boats.
where do I need to start to understand what has succumb to 2020 now.
all guidance appreciated.
also welcome info on good boat mechanic in Chattanooga if anyone knows someone.
