MrMoose
- Calgary, AB, Canada
After 4 oil changes, I finally got tired of leaning over the motors to add oil. The pic shows a 1 qt funnel with a shut-off valve hanging above the engines. Just stick the hose into the engine and pour the required amount. No more leaning over the engines.
Here's the procedure, after draining the oil and replacing the filter:
1. Remove oil caps from the engines.
2. Hang the funnel, with the valve closed.
3. Place the funnel hose into one of the engines.
4. Add a quart of oil into the funnel.
5. Open the funnel valve.
6. Drink beer while the funnel empties.
7. Repeat steps 1 to 6 until the dipstick reading is where you want it.
