Oil filters cross references
mattmila
I was changing the oil filter on my 2013 SX192. I found the Amsoil EaOM103 was too small. Does anybody have any cross references to other filters or should I just use the OEM one?
Thanks
billyb
St. Louis
Limited
Bump...I haven't changed the oil yet, but I have had a hard time finding what oil filter I should use.
Thanks,
Scottintexas
Corinth, TX (DFW)
That info should be in your owners manual, which is also available on Yamaha's website if you register with them. PLEASE do @mattmila (use the @ function) hit me up if you get the data so I can add it to the FAQ!!!
mattmila
Does anybody have a service manual for 2013 SX192 I can download?
My owner's manual refers me to the service manual for the oil filter number?
Thanks
mattmila
Julian,
The Yamaha oil filter for the 2013 SX192 is made by Denso. Its part number is 69J-13440-0300 (00). It costs around $21-$25. I have contacted several auto stores and they do not have other filters to match it. Maybe somebody will have better luck. I will keep on trying.
Ma
Scottintexas
Corinth, TX (DFW)
@mattmila what engine do you have, a 1.8l
bucks448
Sarasota, FL
In 2012 there was a cross-reference for the 1.8L oil filter to WIX which Amsoil matched to EA15K51-ea. I used the filter then, but I haven't been able to find the cross-reference since, and I'm back to using the Yamaha filter.
mattmila
My engine is 1.8L. I don't think the SX192 was made yet in 2012. I maybe wrong.
paul075
Chesapeake, VA
fram PH3614. I use the TG3614 on my VXR.(same engine)
mattmila
Is the VXR the same as the supercharged 1.8L engine?
bucks448
Sarasota, FL
The supercharge 1.8L and the NA 1.8L use the same oil filter.
Boat Crazy
Lebanon Missouri
For more information go to google search and type in...YJB forum oil filter cross over reference.
Cobra Jet Steering LLC
Vendor
Florida
On the 1800 engines I use Motorcraft F L 910 s always have but remember on any oil filter the crimp line is prone to rust and leak some put grease on it but I use aluminum tape to protect the entire case from rust . I started doing this years ago when I saw one in a ski rupture from rust along the crimp .
Top Bottom
