highanddryinco
- Denver, CO
- FSH Deluxe
Yep. Somebody likely did something after the boat left the factory.
You sure this wasn't some sort of demo boat or maybe a boat show floor model that saw a lot of traffic and had to be touched up to look new again. How many hours were on it?Been enjoying my 190 FSH. Its a great boat other than the quality issues I've encountered.
So I finally dropped my boat off at a Yamaha dealer today to investigate the overspray issue and to fix all issues that are wrong with the boat.
I was cordial with them, but expressed how disappointed I am with all of the items wrong with the boat.
The dealer said that they have not seen the overspray issue like mine before. Lets see what Yammy says and does.
Below is the laundry list of items in need of correction that were left with the dealer.
1. Jet wash hose kinked (black hose next to jet pump)
2. Port side combing pads (wavy / bad stitching/ both should be replaced)
3. Overs-spray on center console (black trim near footrest facing aft) most of it has been clay bar’d off by me.
4. Over-spray all over engine area. Engine cover & wires. This overspray all over the engine and engine accessories, hoses, and wires needs to be addressed. Its unacceptable. Already have a call into Yamaha.
5. Starboard side jump seat rubs against sides when lowered and raised. Is causing damage to gel coat.
6. Center console changing area has large scrape/damage on grey paint (is there touch up paint for this?) This seems to been have done at the factory.
7. Anchor locker drain hole missing through-hull fitting. Stem on fitting not long enough. Does not continue all the way through to anchor locker. Water can leak to changing area from this weak seal.
8. Anchor locker - Anchor holder clips cracked (over-tightened)
9. Switch cover missing for "Docking Lights" Clips to hold switch cover broken. Needs all new switch. New cover too.
10. Both floor scuppers leaking. Water going into storage compartment.
11. Glove box latch stripped out. Latch strike cannot be tightened down. Stripped out. Will not latch closed.
12. Gel coat chip underneath helm footrest
13. Front fish locker has multiple issues. Through hull drain is incorrect size for hole. Gap in drain hole was filled w silicon. Water still leaks into compartment.
14. Fish locker has some sort of off white paint all over inside of locker. Could not peel it all out.
15. Gel coat on center console very thin. There are some pores in gel coat by fm radio. There seems to have been repairs. (putty fill ins) One has popped out exposing a chip. Near FM radio.
16. Engine compartment vibration insulation not glued in center of hatch cover. Falling down.
17. Many deck latches are loose. Battery compartment, live well, etc. All should be checked and tightened.
18.Every through hull that I have been able to test leaks. I was unable to test through hulls that were not easily accessible. Please leak check all penetrations.
Im very mechanically inclined and could have fixed a lot of them myself, but why should I?
es no exaggeration with the dealer folks for a &#*in' plastic nut. We weren't delivered the boat we agreed to. They dragged one out of the fenced lot that was full of leaves and crap and were washing it out when we got back to take delivery. It has several flaws. The most irritating is the lid to the bucket well doesn't fit right. I could overlook it but my bride can't let it go. When I removed the bucket well to install the Airmar through hull transducer, I sure hope a robot didn't do the cut out. Two screws are just for looks as the hole was cut out bigger than the screw pattern. Maybe the top cap on the FSH isn't manufactured by robots and the cheapest labor one could possibly imagine is building our $35k boats. Looking back, I regret not buying the one at Barney's Yamaha in St. Pete. We crawled all over and under it and determined it was nearly flawless but a few more d
Thats good to know. So the bucket well is kinda just glued in then? Wanted to pop mine off soon to have a look around in there anyways. Ill check that out.
I'll also make sure not to loose that plastic nut either. Looks like you would have to buy that whole expensive switch just to the plastic nut that comes with it.
So are they covering all of the items on the list except the overspray? They're not denying those too are they?
If they're saying that the dealer screwed the gel coat up, get it in writing and present it to the dealer. Then ask the dealer why the boat that you bought as "new" isn't considered as such by the manufacture. It might be worth hiring a marine inspector to try and find what damage was being hidden prior to your purchase. Honestly, I haven't heard of Yamaha ever sending out a boat with this kind of "over spray". It could've been damaged during transport and poorly repaired prior to delivery, or the dealer did try to cover up some damage too. It's impossible to say how the damage occurred, but IMHO, Yamaha has to back up a boat sold in their certified dealership as new regardless. Also Ask Yamaha where it says in their warranty that your state is excluded and what other items aren't covered on your boat that are elsewhere.
Either way, make it clear to the dealer that he should be figuring out who's going to pay for the repair (dealer or Yamaha) and not your attorney . I feel for you and am surprised that they're not doing whatever it takes to make it right.
defect issues as warrantable items. His excuse for not doing so was since my boat was purchased in Arizona (super hot climate), the boat may have been uncovered and out in the sun at the dealer. And the sun caused most of the defects on the boat.
I hear those Rotax boats have no issues whatsoever, and no-problem warranty coverage. Easy peazy.AS much as I love my 2007 AR , I think this is the last Yamaha for me. The boats are super easy to work on and don't have many mechanical issues but with the current price point I can go to a Competitor and not spend much more for a better built product.
Hope everything works out for you.
I'm being obnoxious, but lets keep it real.
I've had crap workmanship on $130k Mastercrafts.....every manufacture has issues.I guess you missed my point in that a $ 73,000 boat should not have the quality issues that Yamaha is having. If you want to pay that much and have to fix things that the factory should have or the company warranty then go for it. It seems to me that once they came out with the 24 footers and new models that it's been issue after issue. I mean come on, the 2014's or 2015 had to have the complete dash fix because it would come loose.
