- Raleigh, NC 27614
- 242X E-Series
OK, I spent a little time today working on the boat trying to figure out why my starting battery was dead last week. So I go out to there today with a multi meter and sure enough, the starting battery is totally dead again (read like .7 volts). House battery read 12.5v.
So I try putting it on my Craftsman charger but it will not charge it (keeps showing a fault).
So I take it to Advance Auto and they put it on their fast charger and 40 minutes later it is back up to 772 cranking amps out of 800. So back to the boat I go. When I get there I figure I'll give it a bit more of a charge with my charger, and it only gets to the first bar of charge (out of 5 or 6) in half hour to and hour.
Its getting late, so I put the battery back into the boat hook up the negative terminals and before I hook up the positive cable I connect the multi meter to the + terminal and + wire to see if it is drawing any current and I get Zero. When I connect the positive terminals the Wet sounds sound bar on the tower crackles when I touch the wire to the terminal. I do this a few times just to be sure, and it crackles every time I touch the + line to the terminal.
I traced the + and - lines from both amps and they both go to the house battery and not the starting battery.
I'm baffled...but not an electronics expert....so when the new amp comes in I'm going to let them figure it out.
In the meantime I left the + cable off the battery so it wouldn't drain the battery.
