Bill D
- Prairieville, LA
- Limited S
So after seeing all this business about the cone bearings I decided to pull my pumps before the summer. I ran across an issue with the Thrust Vectors... I can't remove the bolt for the steering cable with the TV installed. The spring sits right in the way. Is this a common problem, or was the install done incorrectly? BTW, it appears as though the allen head was stripped and it was tightened with Channellocks.
