haknslash
- Lake Martin, AL
- Moomba
- Other
I can't find the thread I read a long time ago that explained what type of grease the Yamaha Marine Grade A was. I want to say it was the blue grease that is Aluminum Complex. Is this correct? If so this grease I bought should be ok to use and it's compatible?
I also bought a pump grease gun. It says the output is 4 oz per 100 strokes. I checked in my manual and it says at 10 hours fill the bearing housing with 1.18 oz. By my calculation that is 29.5 pumps correct? I noticed that manual said at 100 hours to put in considerably less grease so is the reasoning for so much grease at 10 hours because Yamaha doesn't put much in there when assembling the boat?
