IvanRZB
- Apex, NC
- SX
Hello all,
The last few times I've taken her out I've noticed a metallic-sounding rattle at the stern, reading through various forum threads it seems like this is something I should really check on. I've read some threads on wear ring issues but I'd like to get the forum's advice before I tear into anything.
When I stand on the upper swim platform--above the cleanout port--the rattle sounds like it's coming directly underneath me. Best I could describe it is that it sounds like there is a jar full of quarters down in there. I mostly hear it at idle or low speed when we first start the engine, I don't think it's there at higher speeds but that could be because it gets drowned out by engine noise. The rattle is definitely gone after some run time, and also not apparent even if we've anchored at a cove for a while (~1 hour) and fire the engine back up.
At first I thought it might be the steering and bucket linkages as they have some play and they make a similar rattle when I shake them by hand, but that wouldn't explain why I don't hear it after things have been running for a while.
What should I look for to make sure I don't have a larger issue developing? How far do I need to tear into things?
Thanks in advance!
Thanks in advance!
